not turning over
not turning over
z1100r will not turn over starter circuit relay clicking starter rely /solinid not doing anything .also horns not working all other electrics working ok
- Mark Tiller
jez1100r wrote:Mark Tiller wrote:Have you checked all the fuses, not just visually?
if you out a thick screwdriver across the solenoid terminals does it spin over then?
have not tried that what does it mean if it does turn over .put a new fuse in .old one looked ok
If its "clicking" power is getting to the solenoid - but maybe not enuff available for the starter motor.
As mentioned, check battery voltage/condition. Put lights on then try starter - see if they dim a lot.
Check starter main power lead connections too
PaulMceleney
- Chunks
Users browsing this forum: No registered users and 191 guests
