wire loom
#46 PostAuthor: z1bman » Mon Apr 28, 2014 11:12 am
clock illumination wires are blue so if you have a spare it is probably down to this
Wayne1960
#47 PostAuthor: Wayne1960 » Mon Apr 28, 2014 11:40 am
Thanks Z are the clocks bot on a connector block?
Bike now finished what a joy!
#48 PostAuthor: z1bman » Mon Apr 28, 2014 11:57 am
yes they are in the main harness to the clocks. & it plugs into another block in the headlight. how many wires have you got connected to the blue wire with the double connector coming from the r/h switch ?
Wayne1960
#49 PostAuthor: Wayne1960 » Mon Apr 28, 2014 12:16 pm
Only 1
Wayne1960
#50 PostAuthor: Wayne1960 » Mon Apr 28, 2014 12:36 pm
just had a look at the parts catologue and all the lamps from the clocks and idiot lamps plug into the same plug so it is strange that they are not working.
#51 PostAuthor: z1bman » Mon Apr 28, 2014 1:27 pm
are the fuses ok?
KeithZ1R
#52 PostAuthor: KeithZ1R » Mon Apr 28, 2014 2:43 pm
Find the blue wire that feeds the clock loom behind the headlamp, unplug it take a length of wire from the fed side of the clock loom direct to battery Positive and touch it on if you clocks light up you know the issue is between the lighting live and the connection you have just split
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Wayne1960
#53 PostAuthor: Wayne1960 » Mon Apr 28, 2014 2:54 pm
Thanks Keith ill give it a go. Z yes fuses appear to be ok.
KeithZ1R
#54 PostAuthor: KeithZ1R » Mon Apr 28, 2014 3:04 pm
Just one thing else have you got a good earth connection from the clock loom as weel
Keith
:bop :gom
mistaken.
Wayne1960
#55 PostAuthor: Wayne1960 » Mon Apr 28, 2014 3:36 pm
????? not sure. i have established that the handle bar earth is poor and that's why my horn don't work so maybe this is the problem with the clock light!
#56 PostAuthor: z1bman » Mon Apr 28, 2014 3:50 pm
clock lights/ bulb holders have their own earths. bracket does not need to be earthed
#57 PostAuthor: z1bman » Mon Apr 28, 2014 3:51 pm
have you got power to the blue at the back of the ignition switch ?
Wayne1960
#58 PostAuthor: Wayne1960 » Mon Apr 28, 2014 3:59 pm
Will check tonight.
Wayne1960
#59 PostAuthor: Wayne1960 » Mon Apr 28, 2014 9:26 pm
Thank you all for your combined efforts to sort this and sort this we have.
All working perfect now. So the problem with the horn was as you all said, poor earth. Cleaned off powder coating to handlebar caps and the top bolt. Horn works perfect and very loud!
Clock lights was a lose connection. As soon as I took the front light lens off the clocks lit up. Not sure what was actually wrong but pushed all the connections in tight and could make them fail again.
So all back together.
Thanks again
#60 PostAuthor: z1bman » Mon Apr 28, 2014 9:35 pm
when are we going to see some photo's
Users browsing this forum: micnot54 and 35 guests
