Any ideas where l can obtain 750 Turbo kit or piston assembly part no. 43020-1035 ?
Many thankz
ZX750 E2 TURBO REAR BRAKE MASTER CYLINDER KIT
You will struggle to get a genuine piston kit unless a NOS one turns up on eBay. Every so often pattern ones do turn up on eBay as I got hold of one a while ago. Early ZR7 rear master cylinders do bolt straight up but the hose/reservoir is a larger diameter, it is possible to hose up to your original reservoir though.
Mike
Mike
