main fuse
- Regular Poster
main fuse
hi could anyone help please. I have a Z1b that has been imported & stood up for about 3 years. Ive tidied the bike up & looks very nice but i have a problem. When you start the bike after about 3 minutes of running in neutral or riding the bike about 5 to 10 minutes the main 20A fuse blows. Its done it several times now. Ive changed the regulator & rectifier from my other z1b & the fault still occurs. With a clamp on ammeter that is calibrated the current drawn is no higher than 6 to 7 amps. Any help pls would to be great. regards gerald
HI Gerald, sounds like a short to me connect a 12volts lamp in parallel with the 20amp fuse this should indicate when the short occurs ie it will glow brighter,it may be case of isolating circuits to find the fault favourites are the loom to the bars,cut out switch but of course it could be anywhere as the B only has this one fuse and has no segregation for separate circuits..Good Luck Paul J
- steve bowdler
Some have replaced the fuse with one of these
http://www.ebay.co.uk/itm/260697711758? ... EBIDX%3AIT
I have chenged to blade fuses lot better than the older style fuses
Inspect the blown fuse if it is heavily blackened or shattered you are looking for an intermittent dead short, which you will only find though a process of elimination. A lightly blown fuse indicates a slight overload. I have had problems with the poor contact in the fuse holder causing it to overheat. This in itself could be enough to melt the fuse.
I would fit the relay mod as a matter of course
- Regular Poster
main fuse blowing
Hi thanks for your help to all who replied. I found a short on the loom to the right hand switch. I think ive sorted it because it seems ok now & just had it mot ed. Now to register it & ride it this summer. Thanks again for your help. :D
Users browsing this forum: No registered users and 88 guests
