Side Stand
Wayne1960
Side Stand
#1 PostAuthor: Wayne1960 » Fri May 16, 2014 6:29 am
Side stand fitted but when it comes back to its rest position it misses the rubber stop on the exhaust. If I push it over it will hit but comes back under the tension of the spring.
There is lateral movement which I would expect.
Any ideas?
Bike now finished what a joy!
Charlie
#2 PostAuthor: Charlie » Fri May 16, 2014 7:36 am
I would guess there is wear/play on either the bolt and/or the hole it fits through on the frame.
wilsonsjw11
#3 PostAuthor: wilsonsjw11 » Fri May 16, 2014 8:05 am
Has it been bent :?:
Regards
Steve
Wayne1960
#4 PostAuthor: Wayne1960 » Fri May 16, 2014 12:20 pm
It looks perfectly fine and it wasn't until i fitted the exhaust i realized there was a problem!
Ill have to take the bolt out and have a look at it and the hole.
