Hi Guys
I have been working on my Z1A where i changed the the gasket between the cyclinder head and the cam cover. I just ran the bike down the road on a test run and when I got back I could see some oil leaking from under the cam cover. Can anyone tell me what the torque settings are for the cam cover bolts. I have hand tightened them but i am not sure that is enough. I am a bit heavy handed and so I am trying to avoide damaging and bolts by over tightening them. Would be a great help is someone could let me know.
Thanks Irishkev
Cam Cover Oil Leak
- mick znone
IrishKev, as Z!Bman says 70 IN-Lbs is correct, before tensioning check the usual place for leaks ~ the rubber half-moons.
Also, check for hair-line cracks on the adjacent outside edge bolt supports.
I never use a torque wrench for 6mm bolts, just develop a feel with a small levered 10mm spanner, as Pigford & MikeZ!A suggests.
This is what I use............
1 inch drive ratchet with a 1 to 3/4 stepdown, onto a 3/4 to 1/2 stepdown, onto a 1/2 to 3/8 stepdown, onto a 3/8 to 1/4 stepdown, onto a 10mm single hex socket.
Hope I've been helpful.
Just remember....
"Jimmock's the name and solutions is my game".
Just remember....
Jimmock.
I hate people I don't like !
Users browsing this forum: No registered users and 91 guests
