Leaking from carb overflow only on number 2
Easy I thought, the bikes been stood a while, so I removed carbs, cleaned the float valve.
Put some new fuel lines and fitted in line filters and I thought that would be the end of it. Nope still leaks only a few drips a minute but it bugs me.
Ok, plan B. Ordered a carb overhaul kit and fitted the new valve and seat. Just put it back together, guess what no difference..........
Any ideas/advice appreciated, I must be missing something.
Its a 1000 a1
Nick
Its a 1000 a1
Nick
Float not upside down by any chance? or check the little brass pipe at float bottom these sometimes split letting fuel through....PaulJ
Or hole in float!!!!
Make a manomter to check fuel height from piece of clear tube,put float in petrol see if it leaks,ie sits lower than the others
Hasbeen wrote:Do you mean the pipe in the bowl which attaches to the overflow?, not checked that
Yes see above as well
- steve bowdler
Hasbeen wrote:You guys are good. It seems the little brass pipe leaks, how does that happen?, I filled bowl with soapy water and blew up pie and bubbles!!
Whats the solution guys now please?
New bowl or i have had success with a fine blow torch and solder you will find there is a hairline split in the pipe,Glad to help Paul J
http://www.ebay.co.uk/itm/Brass-Tubes-2 ... 53f042efb0
just twist the brass tube with some pliers & it should come out
Users browsing this forum: No registered users and 172 guests
