What engine is it KZT00AE037907
Padders
#1 PostAuthor: Padders » Thu Aug 31, 2006 12:36 pm
Can any of you guys help me with identifying the engine I have just bought from HOBBO. It is 1015cc 8mm studs engine number KZT00AE037907. Is it A2 Z1R Import etc.
Cheers Ian.
uk kev
#2 PostAuthor: uk kev » Thu Aug 31, 2006 1:27 pm
1977 Z1000-A1
FRAME NUMBER: KZT00A-000001 >
ENGINE NUMBER: KZT00AE-000001 >
steve f
#3 PostAuthor: steve f » Thu Aug 31, 2006 4:50 pm
as above the z1000 A1 engine no finish's at KZT00AE004018
uk kev
#4 PostAuthor: uk kev » Thu Aug 31, 2006 5:02 pm
But the A2 number never started untill 042501, which makes the above number an A1.
Are you saying that the A1 only sold 4018 units worldwide Steve, or am I missing the point, or have you missed a number out?
1978 Z1000-A2
FRAME NUMBER: KZT00A-027501 >
ENGINE NUMBER: KZT00AE-042501 >
#5 PostAuthor: Rich » Thu Aug 31, 2006 5:42 pm
I think it's a Kawasaki ;)
steve f
#6 PostAuthor: steve f » Thu Aug 31, 2006 6:11 pm
1978 Z1000-A2
thats what it says in themodel recognition manual unless the book is printed wrong as i have looked again maybe they got a digit wrong and it should be
KZT00A040018 ???? NOT
KZT00A004018 CERTAINLY LOOKS BETTER
#7 PostAuthor: Rich » Thu Aug 31, 2006 6:34 pm
4018 is the start number for models made in America.
Ian your number refers to an A1 or B1 ltd, A2s start at 040605, The A1 should have a nylon thread to the clutch actuation mechanism, I think this is the only difference engine wise between them, but if people have any sense they've replaced it with a later "ball" mechanism. Z1Rs are D1s and have a D in the number instead of the A in AE.
Which is all irrespective really but you may buy me a pint for it!
Padders
#8 PostAuthor: Padders » Thu Aug 31, 2006 7:13 pm
Just checked not the nylon type so does that make it a B1 or an A1 that has had a later mech fitted. Not too fused just wanted to make sure I had genuine numbers.
I'll buy you a pint Rich just because you replied without mentioning S*****N frames.
Cheers Ian.
#9 PostAuthor: Rich » Thu Aug 31, 2006 8:25 pm
According to your frame numbers it'll be an A1 or B1, same engine - just the B1 was the American chopper thing! The nylon actuator was used upto engine 25467 and superceeded by the ball version which was much better, so I would expect your engine to be a late A1.
Padders
#10 PostAuthor: Padders » Thu Aug 31, 2006 9:04 pm
Cheers time to get stripping the thing and hope I find nothing untoward lurking inside! Has Dyna S ignition fitted which was a nice bonus. Hobbo thought it had the system fitted but we never checked when I collected the engine.
Ian.
#11 PostAuthor: Rich » Fri Sep 01, 2006 2:14 pm
You only ever know what it's like when you take it to bits!
