Rebor
Wayne1960
Rebor
#1 PostAuthor: Wayne1960 » Thu Aug 07, 2014 4:30 pm
Is it possible to have my Z900 A4 rebored and still keep the same pistons? is there an acceptable limit?
Bike now finished what a joy!
zpower
#2 PostAuthor: zpower » Thu Aug 07, 2014 4:40 pm
Simple answer is no you will require new pistons after a rebore.
** Special rates for the Z1OC forum members **
Website design, hosting / domain names.
Computer and Laptop repairs.
#3 PostAuthor: PAULJAC47 » Thu Aug 07, 2014 4:49 pm
Unless you have new liners put in !
Wayne1960
#4 PostAuthor: Wayne1960 » Thu Aug 07, 2014 4:49 pm
What's the next size up and I guess ZPower stock the pistons and rings?
Mark Tiller
#5 PostAuthor: Mark Tiller » Thu Aug 07, 2014 5:36 pm
Take it up in capacity....no substitute for cubes
07962421462
Wayne1960
#6 PostAuthor: Wayne1960 » Thu Aug 07, 2014 5:59 pm
Can you get new liners? can i fit them myself?
DogsbolloxofZ1B
#7 PostAuthor: DogsbolloxofZ1B » Thu Aug 07, 2014 6:23 pm
Hmmmm
It should be possible to re-cross hone your bores and keep within the serviceable limits, but not re-bore as other state. Modern X honing from companies like SERDI UK is done to within microns using inline auto honing machines. You'd have to measure the bore using a bore gauge, pistons and work out if you had enough meat left in the bores. If you do, get some new rings and re-gap correctly. Plenty of ass grease and away you go, rings should lap themselves in after a few tens of miles.
Mike
#8 PostAuthor: chrisu » Thu Aug 07, 2014 7:01 pm
why do you think it needs a rebore ?
have you measured it ?
as zpower says - rebore = new (different) pistons.
if you do go down this route price up a wiseco set of pistons against the standard kawasaki ones.
Wayne1960
#9 PostAuthor: Wayne1960 » Thu Aug 07, 2014 10:03 pm
Chris
Smoking on 1 & 2 !! 3 & 4 fine checked plugs on 1& 2 and wet.
#10 PostAuthor: z1bman » Thu Aug 07, 2014 10:28 pm
have you measured to piston to bore clearance? is the bore scored? what are the piston ring end gap clearances when installed in the bore ? are the valve guides in good condition & fitted with new quality valve stem seals
Wayne1960
#11 PostAuthor: Wayne1960 » Fri Aug 08, 2014 2:48 am
Hi Zed
Engine feels like it's running well now but when I had the problem with the piece of metal in the chamber I spent the day with Buzzard.
We tidied up the head so I could use it to get the bike finished which I have. However we established that the bores were scored and the valve guides shot.
Ian keen to keep the engine 903 original spec so the first thing I need to do is sort out the cylinders.
Pistons measured ok and rings all new so I'm guessing the scores are causing the problem.
So can I swap the out for new?
Gavin
#12 PostAuthor: Gavin » Fri Aug 08, 2014 6:10 am
Give it a compression test before stripping down, it may just be valve stems seals
Z1000 MK2
Z1300 DFI
#13 PostAuthor: chrisu » Fri Aug 08, 2014 6:22 am
Another set of barrels?
But get the valve guides/seals done before you put it back together
Wayne1960
#14 PostAuthor: Wayne1960 » Fri Aug 08, 2014 7:11 am
Ok I'll do another compression test which I did before and I had what I thought was good compression about 8 on each.
In fact the worst was was cylinder 3 and that and 4 doesn't smoke at all it's only 1&2
Don't really understand why but Buzzard did say it would smoke but it should smoke on all 4
Say I've got good compression! I have already confirmed the plugs are damp.
So can I buy new cores and keep my block if I need to?
#15 PostAuthor: ADRIAN H » Fri Aug 08, 2014 8:03 am
You can buy liners here. Think this is priced for one liner.
http://japan.webike.net/products/2505366.html
Or ask Zedhead on saisei-europe.com.
