z 1300
				Sha Hoorsur
 - Regular Poster
z 1300
Almost finished rebuilding my z1300. Connected the battery, ignition lights come on, pressed the starter switch. Nothing.
Everything looks to be connected, I'm rubbish with electrics, where do I start?
Short across the solenoid with an insulated driver see if she turns over and starts,if so see if you have  power going to the small wires on the solenoid if so suspect faulty solenoid if not usual suspect is the kill switch or starter button,get hold of circuit diagram and trace the wiring if not,get a good colour diagram and be methodical..Good luck Paul J
Re: z 1300
Sha Hoorsur wrote:Almost finished rebuilding my z1300. Connected the battery, ignition lights come on, pressed the starter switch. Nothing.
Does it have a clutch switch?.....
				Sha Hoorsur
 - Regular Poster
Re: z 1300
Well known problem Z13 wires to the starter short out. I've got one
				Sha Hoorsur
 - Regular Poster
Going to have a little drink now, medicinal purposes you understand. Yes, I know alcohol won’t solve your problems. But I can have fun while I try. So any postings made by me between now and bed time are guaranteed to make no sense whatsoever. On account of me being a bit rat arsed.
No change there then.
Might , just might be the kill switch.. I  would trace the wire from the switch, might go into the headlight, or back of the clocks ( just guessing on this one) and should be a connector block, unplug it, and take a look at the contacts... Spray some wd40 in both sides, re connect and try again.. Failing that, you will need a meter, and test the wires coming from the switch,  kill switch on... And off, and see if you get a circuit, if not  it's the switch...  And take it off and send it to me, for a strip down, and might be the contacts inside it..that's if you don't get it sorted. I have refurbished.. Kawasaki, Suzuki, Laverda switches, but not a z1300 yet, what's the saying.. There's a first time for everything.. Thanks ..
				Is Vic There
				Sha Hoorsur
 - Regular Poster
The saga continues, not much further forward today.
If I put a screwdriver across the starter solenoid terminals the engine turns over. I have power to the, on off, switch on the handlebars, but no power to the starter switch. I have checked all the connections and they seem to be ok. I’ve got a side light indicators rear light but no headlight.
I don’t know if it will start because I have not fitted the petrol tank yet.
It's not the seat switch, I know about that, it was running before I dismantled it.
Still resisting the urge to do a Basil Fawlty on it.
