bad earth?
sweptail
bad earth?
#1 PostAuthor: sweptail » Thu Aug 21, 2014 4:59 pm
I have a situation where if i turn the ignition on, my 20amp fuse blows instantly unless i leave the kill switch in the OFF position, then its fine. If i take the R/H switchgear off the bars, i can start the bike---- no probs.
I recently done some work on coils and headlight, so i may have disturbed something. My trouble is im hopeless withh electrics. What next?
Tommy
sweptail
#2 PostAuthor: sweptail » Thu Aug 21, 2014 5:00 pm
900a4 :)
#3 PostAuthor: Pigford » Thu Aug 21, 2014 5:22 pm
The kill switch is earthing out on the bars - check the wiring - it'll be dodgy :?? probably wires squashed between bars & switch casing :?:
z1000puddin
#4 PostAuthor: z1000puddin » Thu Aug 21, 2014 5:23 pm
Tommy,
Check the wires that come from the kill switch.
There must be a wire that is earthing against the handle bars when you are fitting the switch gear on.
Stu
Zed til Dead
z1000puddin
#5 PostAuthor: z1000puddin » Thu Aug 21, 2014 5:24 pm
FFFS Piggy
I am too bloody slow again !!!
Zed til Dead
#6 PostAuthor: Pigford » Thu Aug 21, 2014 5:25 pm
z1000puddin wrote:FFFS Piggy
Beat you by 6 seconds :lol: At least we agree :wink:
sweptail
#7 PostAuthor: sweptail » Thu Aug 21, 2014 7:38 pm
i did avalook inside the swichgear and it was a bit grotty: cleaned up wot i could get at. wires and soldering looked good. I`ll have alook again tmrw.
Oh... I replaced the frayed neg earth lead from batt to engine with the 9inch Halfords item the other day: slightly thicker. Shouldn`t be a problem should it?
Thanks boys
jimmock
#8 PostAuthor: jimmock » Thu Aug 21, 2014 8:25 pm
sweptail wrote:i did avalook inside the swichgear and it was a bit grotty: cleaned up wot i could get at. wires and soldering looked good. I`ll have alook again tmrw.
Thanks boys
The bigger the earth the better.
Jimmock. :wnkr
I hate people I don't like !
