carbs
Roy there are five 8mm headed M5 bolts holding the shaft .
Four are under each carb top holding the linkage to the shaft , the fifth holds the cable quadrant to the shaft , undo all five .
On the carb backplate between carbs 1 and 2 there is a Phillips screw holding a retainer in a rebated groove on the shaft , undo this screw .
With all six of these bolts removed the shaft will slide out giving you access to all the slides .
0172 . Geoff Parr
