Z1B Carbs
Z1B Carbs
Hi guy's, on inspecting the carbs I have prior to a strip and rebuild i noticed there is a hairline crack in the rack they are mounted on, anyone know if this is made from alloy that will weld or am I looking for a new rack?
- wheelysteve
I repaired one some years back.
drilled a small hole (3mm?)at the end of the crack,'key' the plate, filled the hole and crack with chemical metal. Left to harden, filed/ smoothed,painted.no future problem
cheers freddy
cheers freddy
freddyz1r
PUM 329
freddyz1r
PUM 329
