Air Assisted Shocks
evans
Air Assisted Shocks
#1 PostAuthor: evans » Tue Oct 21, 2014 4:03 pm
I have air assisted shocks on my 77' z1000A1, but do not know what they are actually off. This is a problem when it comes to quants of fork oil, seals etc.
Can anyone suggest from which bike they might be from ? They have caps in the top with holes in, which has meant that the recessed square plugs underneath in the top of the forks are rusted/ceased solid and can't be removed to fill with oil.
freddyz1r
#2 PostAuthor: freddyz1r » Tue Oct 21, 2014 5:16 pm
Got any pics :?:
what diameter are the tubes :?:
there are numerous models with 'air assistance', more information is needed for process of elimination :??
Cheers freddy :D
freddyz1r
PUM 329
Yellow
#3 PostAuthor: Yellow » Tue Oct 21, 2014 6:27 pm
Also have air assisted on my A1. Previous owner replaced original fork tops with after market ones with air fillers on. Work well, remainder of forks are standard.
#4 PostAuthor: z1bman » Tue Oct 21, 2014 6:34 pm
Oxygen/Acetylene will move them
evans
#5 PostAuthor: evans » Fri Oct 24, 2014 10:50 am
Thanks for your replies. How do I put photos on here ?
Big Fluff
#6 PostAuthor: Big Fluff » Fri Oct 24, 2014 10:57 am
Could be Kawasaki 1100 Spectre.?
evans
#7 PostAuthor: evans » Fri Oct 24, 2014 1:30 pm
how do I put photos on here ?
freddyz1r
#8 PostAuthor: freddyz1r » Fri Oct 24, 2014 1:36 pm
evans wrote:how do I put photos on here ?
follow 'zordeds' sticky :?:
freddyz1r
PUM 329
KeithZ1R
#9 PostAuthor: KeithZ1R » Fri Oct 24, 2014 1:43 pm
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
evans
#10 PostAuthor: evans » Sat Oct 25, 2014 1:44 pm
See photos. Might be best for me to replace with new upper forks as they are pitted. Any ideas where I can get them from ?
#11 PostAuthor: z1bman » Sat Oct 25, 2014 2:57 pm
those look like gpz 750 r1 forks = 36mm diameter
freddyz1r
#12 PostAuthor: freddyz1r » Sat Oct 25, 2014 5:18 pm
What diameter tubes are they???
Cheers freddy :D
freddyz1r
PUM 329
evans
#13 PostAuthor: evans » Sun Oct 26, 2014 12:32 pm
They are 36mm diam. Wheels are GPZ900. Any thoughts on where I can get a new set of upper forks from ?
Chris
#14 PostAuthor: z1bman » Sun Oct 26, 2014 12:52 pm
this gives you the diameter & lenght
http://www.wemoto.com/bikes/kawasaki/gp ... _-_single/
jimmock
#15 PostAuthor: jimmock » Sun Oct 26, 2014 1:01 pm
The H***** CB900/1000 C 10 speed had them too (on the rear)!!!
Jimmock. :wnkr
I hate people I don't like !
