A4 Voltage Regulator
#1 PostAuthor: PAULJAC47 » Tue Dec 09, 2014 5:33 pm
Guyz on a Standard seperate A4 regulator what is the brown cable for? Ta
#2 PostAuthor: z1bman » Tue Dec 09, 2014 7:00 pm
its the switched live feed
#3 PostAuthor: PAULJAC47 » Tue Dec 09, 2014 7:33 pm
Hi Z1b Man,so would i be correct in that this brown becomes live when the ignition switch makes between white and brown? and is in turn regulated voltage wise inside the regulator by means of a defined voltage threshold Zener diode or similar dumping excess volts to ground,which keeps the main brown live feed to the bikes main system stable voltage wise?..Thanks in Advance Paul J
#4 PostAuthor: z1bman » Tue Dec 09, 2014 8:01 pm
yes that is correct :D
#5 PostAuthor: PAULJAC47 » Tue Dec 09, 2014 8:58 pm
Ta for that!!!!
