Wiseco 1170 10.25 or 9.5 ?
Just about to order a Wiseco 1170 kit for my 1100 Unitrak Harris motor.
Should I go for the K1172 High Compression 10.25:1 or the more standard K1173 9.5:1 kit?
...or to put it another way; any known issues with the 10.25:1 ?
TIA
TIA
Best UK price I've found for a K1172 is BigCC Racing who want ~ £470
On EBay there's Item 231285625526 which would work out at ~ £400
I'm going to order from Jeff @ Z1Enterprises who's halfway between those prices or maybe less if HMCRE are feeling overworked
FYI, Jeff did note that Wiseco price rises tend to happen on the 1st Jan so ordering now might be a good idea.
Thanks for the info, Andyruffle wrote:Best UK price I've found for a K1172 is BigCC Racing who want ~ £470
Thanks for the input chaps.
I've gone for the 10.25:1 as although there were some negative comments nobody actually said they'd blow up one's motor, burn down the house, rape chickens and bite the heads off virgins
I'll run super-unleaded and even a dollop of octane booster (this is for my Harris Magnum so I'll not be touring on it!) and see how I go.
ruffle wrote:Thanks for the input chaps.
Mine was gas flowed head, std cams, RS36 carbs (which are NOT too big!) and she pinked a bit at wider "laboured" throttle openings at lower revs .... but did that for the 10 yrs I owned her with no problems.... also had a fair bit of thrashing at the 1/4 mile, etc
Users browsing this forum: celger7 and 38 guests
