Fork spring lengths
Richard Q
Fork spring lengths
#1 PostAuthor: Richard Q » Fri Dec 26, 2014 9:45 pm
The only workshop manual I have is for the Z1, and mine is a KZ900.
It says the fork spring is 495.5mm long with a service limit of 485mm. I have measured mine at 467mm :??
I can only assume that the A4 ones are shorter, or mine are totally FUBAR.
Are they shorter? and if so I also have to assume the oil could be a different viscosity, amount, distance from the top of the fork. Does anyone have the correct figures please?
Much appreciated - Cheers
Ruchard
1976 KZ900
PaulMceleney
Chunks
#2 PostAuthor: PaulMceleney » Sat Dec 27, 2014 11:37 am
my measure 465 mm in a z1000 a1 just got some new progressive springs that measure 535 mm from z power
Richard Q
#3 PostAuthor: Richard Q » Sat Dec 27, 2014 8:45 pm
Thanks Paul
Been doing some reading and found some conflicting stuff, but one says they are 465mm and have a limit of 455mm, so I am going with that.
170ml of 10 grade fork oil, and 426mm from the top with the spring fitted.
How are you going to fit 535mm springs into a 465mm fork? Best of luck with that :)
Richard
1976 KZ900
Users browsing this forum: celger7 and 37 guests
