Calipers go where?
Richard Q
Calipers go where?
#1 PostAuthor: Richard Q » Sat Jan 03, 2015 8:17 pm
So, when I stripped the bike, the speedo cable was cable tied to the brake hose instead of going through the bracket designed for it. So, I googled images for Z900s to get an idea of how it should look.
Most of the images showed the images showed the calipers in front of the forks, so why are mine behind them?
1976 KZ900
#2 PostAuthor: z1bman » Sat Jan 03, 2015 8:31 pm
the reason is the forks need to be swapped over left to right
mick znone
#3 PostAuthor: mick znone » Sat Jan 03, 2015 8:33 pm
some preferred to swap them round to give the bike a more modern look.
freddyz1r
#4 PostAuthor: freddyz1r » Sat Jan 03, 2015 8:35 pm
Richard, as z1bman says :up just take the legs out and swap 'em over :wink:
r u replacing the brake lines :?:
cheerz freddy :D
freddyz1r
PUM 329
Richard Q
#5 PostAuthor: Richard Q » Sat Jan 03, 2015 8:55 pm
Thanks all - I've only just re-fitted them! :(
I wasn't going to renew the brake pipes Freddy, they are almost new, braded ones. Oh well, out with the credit card again :shock:
Richard
1976 KZ900
#6 PostAuthor: PAULJAC47 » Sat Jan 03, 2015 8:56 pm
There is a school of thought that they are more efficient behind the forks!
#7 PostAuthor: Pigford » Sat Jan 03, 2015 9:11 pm
Main reason is to speed up steering as there is less effect from the mass of the calipers when they're at the rear of the legs, rather than on top :!:
freddyz1r
#8 PostAuthor: freddyz1r » Sat Jan 03, 2015 9:29 pm
IMO richard, the solid metal pipes (similar to the link below),look better if the caliper is on the front of the legs. The flexible braided hoses don't seem to sit/fit/look right if on the front. Just my opinion, might be worth a look.
http://www.saisei-europe.com/Shop/Produ ... pipe-z1-rh
Cheerz freddy :D
freddyz1r
PUM 329
#9 PostAuthor: z1bman » Sat Jan 03, 2015 9:36 pm
freddyz1r wrote:IMO richard, the solid metal pipes (similar to the link below),look better if the caliper is on the front of the legs. The flexible braided hoses don't seem to sit/fit/look right if on the front. Just my opinion, might be worth a look.
Cheerz freddy :D
you should have enough length on your braided lines to get them modified to take the female fitting that is required to match up with the metal pipe
female fitting is similar to this
http://www.aliexpress.com/store/product ... 79807.html
Richard Q
#10 PostAuthor: Richard Q » Sat Jan 03, 2015 11:22 pm
Hmmm.... I'll have to have a ponder on this.
Turn the forks around and spend 60 odd quid on hoses, or leave them where they are?
1976 KZ900
coldsummer
#11 PostAuthor: coldsummer » Sat Jan 03, 2015 11:27 pm
Pigford wrote:Main reason is to speed up steering as there is less effect from the mass of the calipers when they're at the rear of the legs, rather than on top :!:
The other rumour doing the rounds back in the day was that there was less fork dive on heavy braking but I don't know about that, probably had no noticeable affect?
#12 PostAuthor: z1bman » Sun Jan 04, 2015 12:01 am
almost every modern day bike has the calliper mounted at the rear i doubt if you would even notice any difference. if your happy with the look & brake performance leave them alone
needaz1100r
#13 PostAuthor: needaz1100r » Mon Jan 05, 2015 11:20 am
Actually, no effect.
Mark.
Mark Tiller
#14 PostAuthor: Mark Tiller » Mon Jan 05, 2015 2:28 pm
I think the hoses would reach the other way round
07962421462
garyd
#15 PostAuthor: garyd » Mon Jan 05, 2015 9:32 pm
Mark Tiller wrote:I think the hoses would reach the other way round
Remember swapping mine round as sson as I got mine back in '77. Had no issues with the hoses.
Users browsing this forum: celger7 and 37 guests
