Fork Cover
nicomkii
Fork Cover
#1 PostAuthor: nicomkii » Tue Jan 20, 2015 6:06 am
When I got the MkII it had those cheap aftermarket Fork Ears for the Headlight on it. Attempting to bring it back to standard and somwhere along the line I picked up some repro Fprk Covers ( Part No. 44064-025)
Went to slip them on last night and oops too tight. Obviously not of the original pattern but what I need so I don't butcher these ones is the original measurement.
What I have now is -
Rough measuring
Around 110mm
They even look wrong, never took them out of the box they went straight into the cupboard
Internal appears right.
So just need to know how much to trim from the inside part so not as obvious. Going to be fun trimming them !!!
jphaynes669
#2 PostAuthor: jphaynes669 » Tue Jan 20, 2015 6:50 am
Hi Nicomkii, it could be tricky triming out the inner edge and it could end up very sharp, what about cutting small verticle slits in the inner edge . This might make it less rigid and give it a spring loaded effect when sliding onto the leg, :|
Jeff.H
Z1RII
#3 PostAuthor: Z1RII » Tue Jan 20, 2015 3:52 pm
the fork cover looks like a Z1 part, they are different to z1000/MKII
regards
amir
#4 PostAuthor: z1bman » Tue Jan 20, 2015 5:12 pm
z1000 a3/a3a are the same as the z1/ z1000 but the z100a4 is different
nicomkii
#5 PostAuthor: nicomkii » Wed Jan 21, 2015 1:00 pm
z1bman wrote:z1000 a3/a3a are the same as the z1/ z1000 but the z100a4 is different
And the difference is :?:
They were sold to me as MkII but they may possibly be the later A4. No point butchering them if they are, best I just keep an eye out for A3 ones :)
#6 PostAuthor: z1bman » Wed Jan 21, 2015 2:04 pm
no 20-1 in the parts diagram diagram is what is listed for the a4 but it looks like it just sits under the headlamp ear & is not as deep as the one you have
http://www.cmsnl.com/kawasaki-1979-kz10 ... ml#results
there are some from this seller on e bay
http://www.ebay.de/itm/Kawasaki-Z-1000- ... 1044243705
Z1RII
#7 PostAuthor: Z1RII » Thu Jan 22, 2015 3:49 pm
Z1 Z1A/B covers are different to Z900A /Z1000
the later covers do not have as much metall like the Z1 covers. (sorry, cannot explain correct in english) since the top yolk with it´s bolts is different.
the later MKII A4 does not have covers any more, just a ring plus the plastic cover at the front covering the brake splitter
grez
amir
Users browsing this forum: celger7 and 36 guests
