mikuni vm needle jets required
lescr
#1 PostAuthor: lescr » Mon Feb 02, 2015 10:49 am
Hi all
I am refurbing some z1000 28mm carbs and need to replace the needle jets (the bit that has lots of little holes in and what the main jet screws into) any ideas where I can get some from
Les
#2 PostAuthor: z1bman » Mon Feb 02, 2015 11:57 am
#3 PostAuthor: PAULJAC47 » Mon Feb 02, 2015 12:03 pm
Sounds like you are describing the emulsifacation tubes,the needle jet screws into the bottom of these,not usual for these to fail,just a matter of careful cleaning ideally in an ultrasonic cleaner..
lescr
#4 PostAuthor: lescr » Mon Feb 02, 2015 12:19 pm
Yep they are the ones. Looks like someone has over tightened them, cause they are all buckled.[/i]
#5 PostAuthor: PAULJAC47 » Mon Feb 02, 2015 2:44 pm
Bloody hell never came across that,not sure you can get those you know,put some pics up in Wanted and what they are for,i will have a look see what i have got...Paul J
#6 PostAuthor: z1bman » Mon Feb 02, 2015 3:54 pm
lescr
#7 PostAuthor: lescr » Mon Feb 02, 2015 4:24 pm
[quote="z1bman"]http://www.ebay.co.uk/itm/Kawasaki-KZ1000-Mikuni-Carburetor-Bleed-Pipes-16047-006-/131404585546?pt=Motorcycles_Parts_Accessories&hash=item1e9852da4a[/quote]
looked at these, they look like the ones from the 26mm carbs. The ones I am after have more holes in them. 3 rows of five holes. I will attempt to post a picture
lescr
#8 PostAuthor: lescr » Mon Feb 02, 2015 5:40 pm
[URL=http://s1126.photobucket.com/user/mudzook01/media/mikuni%20bleed%20pipe/SAM_1335.jpg.html][IMG]http://i1126.photobucket.com/albums/l612/mudzook01/mikuni%20bleed%20pipe/SAM_1335.jpg[/IMG][/URL]
These are the bleed pipes that I am after if I have managed to download them from photo#ucket
#9 PostAuthor: PAULJAC47 » Mon Feb 02, 2015 5:55 pm
Pics Not showing up ,i have found some tubes though!
lescr
#10 PostAuthor: lescr » Mon Feb 02, 2015 5:58 pm
http://s1126.photobucket.com/user/mudzo ... sort=3&o=0
these are what I am after.
Finally cracked how to link photos from photo#ucket to forums :hoo
#11 PostAuthor: PAULJAC47 » Mon Feb 02, 2015 6:37 pm
It is a skill putting pics on here,looking at the ones i have they have 6 holes not the 5 you require..
Z1parR
#12 PostAuthor: Z1parR » Mon Feb 02, 2015 6:44 pm
Never seen them bent like that :shock:
Give me ten minutes Les i'll see what i've got in my garage .
0172 . Geoff Parr
#13 PostAuthor: PAULJAC47 » Mon Feb 02, 2015 6:47 pm
Perhaps Uri Geller workEd on Em at one time :lol:
lescr
#14 PostAuthor: lescr » Mon Feb 02, 2015 6:53 pm
[quote="PAULJAC47"]It is a skill putting pics on here,looking at the ones i have they have 6 holes not the 5 you require..[/quote]
To be honest I dont know what difference it would make. The ones you have have less holes but are bigger diameter than mine so would probably allow the same amount of volume through. To be on the safe side I will keep searching for the 5 hole ones.
Been speaking to allensperformance but he cannot help me unless I can supply him with the code number which is stamped on the tube. Ive never seen a number on any of the ones Ive handled so as a last resource I can send him one as a sample to match up. Thanks for taking time to search some out
Les
#15 PostAuthor: z1bman » Mon Feb 02, 2015 6:57 pm
is the carb body ok? there has been some serious force put on those to do that damage i am surprised it didn't break the casting or push the other needle jet through the base of the carb
Users browsing this forum: Bing [Bot] and 18 guests
