mikuni vm needle jets required
#16 PostAuthor: PAULJAC47 » Mon Feb 02, 2015 6:59 pm
Dont think it would make much diff as all they do is help with the emulsification,
the jet in the bottom meters the amount of fuel,good luck trying to find some,will keep a look at for you me self.
Z1parR
#17 PostAuthor: Z1parR » Mon Feb 02, 2015 7:03 pm
Sorry it's a no from me .
Mine only have rows of three holes .
They're from a set of 28s but were a set of pumpers .
0172 . Geoff Parr
lescr
#18 PostAuthor: lescr » Mon Feb 02, 2015 7:05 pm
A visual check shows no cracks. Changing the top needle jet later in week so any damage should show up then.
lescr
#19 PostAuthor: lescr » Mon Feb 02, 2015 7:07 pm
[quote="Z1parR"]Sorry it's a no from me .
They're from a set of 28s but were a set of pumpers .[/quote]
Thanks anyway geoff, I appreciate you having a look.
Z1parR
#20 PostAuthor: Z1parR » Mon Feb 02, 2015 7:11 pm
You should too Les , it's feckin freezing out there :lol:
0172 . Geoff Parr
#21 PostAuthor: PAULJAC47 » Mon Feb 02, 2015 8:41 pm
Makes me suspect these may not even be the correct tubes,overlong maybe?
Steve Cooke
#22 PostAuthor: Steve Cooke » Mon Feb 02, 2015 9:10 pm
PAULJAC47 wrote:Makes me suspect these may not even be the correct tubes,overlong maybe?
I thought that myself so I've just measured the ones on a set of VM28's I have and from the o-ring seat to the end is 27mm and a rough measure in the casting is very near the same maybe 1mm max clearance so it's possible they have been screwed home sometime without the o-ring maybe. These ones do have 3 rows of five holes so they're probably the right ones.
lescr
#23 PostAuthor: lescr » Mon Feb 02, 2015 9:15 pm
Any chance they are available :)
#24 PostAuthor: z1bman » Mon Feb 02, 2015 9:24 pm
there are three different part numbers for this part all are no longer available
#25 PostAuthor: PAULJAC47 » Mon Feb 02, 2015 10:52 pm
Gonna be a hard to find part!
#26 PostAuthor: z1bman » Mon Feb 02, 2015 11:33 pm
nrp do carb repair kits with the emulsion tube included it would be worth giving them a call to see if they do one for the z1000 they do a standard kit on there site but not one with the emulsion tube. they do them for the z1300 & Yamaha virago & they are not as popular as a z1000
http://www.nrp-carbs.co.uk/
lescr
#27 PostAuthor: lescr » Wed Feb 04, 2015 10:56 am
[quote="PAULJAC47"]Gonna be a hard to find part![/quote]
Beginning to realise that. Going to give nrp a call later today if no joy with them then I will fit the type with less holes but bigger diameter. I should be able to adjust mixture ok. Good news is that I cannot see any damage to needle jet seats or body of carbs
Farmer
#28 PostAuthor: Farmer » Wed Feb 04, 2015 9:44 pm
Andy at NRP is a very knowledgeable man :)
1981 KZ1000 K1 LTD
lescr
#29 PostAuthor: lescr » Thu Feb 05, 2015 7:38 pm
no joy with NRP and allens performance are adamant that there are no such carbs as the vm28. :??
#30 PostAuthor: z1bman » Thu Feb 05, 2015 8:23 pm
he has parts listed for vm 28mm on his parts list but the z1000a1 should have vm 26 as standard . are there any numbers stamped on the needle or the jet?
