front brake caliper ...?
bunnysZ
Granny Magnet
#1 PostAuthor: bunnysZ » Mon Dec 31, 2007 10:11 am
I am going to upgrade my bike from single to double caliper
the calipers i have differ slightly, in that the piston on one pair is solid , the other pair are empty, (as photo), the question is why the difference which is better/why and what models are they from.
#2 PostAuthor: Pigford » Mon Dec 31, 2007 10:15 am
BunnyZ, could be a replacement aftermarket part, or someones just fitted it in arse-about-face :?:
DogsbolloxofZ1B
#3 PostAuthor: DogsbolloxofZ1B » Tue Jan 01, 2008 5:23 pm
I agree, the one on the LHS is correct orientation.
dr.rod
#4 PostAuthor: dr.rod » Wed Jan 02, 2008 9:16 pm
The right hand piston has a ceramic insert to prevent heat transfer from the brake pad to the brake fluid in the caliper. It was a development on later models to prevent brake fade.
In real life it makes not a jot of difference.
scott
Junior Section leader
#5 PostAuthor: scott » Wed Jan 09, 2008 4:03 pm
Hi bunnyz,
i agree with dr.rod....i went through the same process as you did when converting kz1000a2 to a twin disc setup. Also make sure the disc thickness is the same as the one you already have....the american one is thicker than the euro one.
Scott
Users browsing this forum: Noblester and 37 guests
