Engine Removal
DavidZ1R
Engine Removal
#1 PostAuthor: DavidZ1R » Sat Feb 28, 2015 2:40 pm
I am about to remove the engine from my Z1R to clean up, have followed the manual to remove all the bits ready, two bloke coming to help out, timber platform made same height as the frame to slide onto, trolly jack ready, do I need to remove the cam cover, looks very close for clearance, or even the sump? any tips would be usefull, cheers.
Z1parR
#2 PostAuthor: Z1parR » Sat Feb 28, 2015 2:45 pm
Leave the sump on , it's a handy flat ish surface .
I take the rocker cover off and the cams out .
Tape up your front frame tubes as your exhaust studs WILL scrape .
Watch the lower rear engine mount scratching right hand side of cradle on the way out and in .
0172 . Geoff Parr
floydsz1
#3 PostAuthor: floydsz1 » Sat Feb 28, 2015 2:45 pm
I remove the camcover. If im pulling the engine apart i also remove the top camchain guide to give a bit more room though you dont need to.
Z1b,
zxr750 m2,
zrx1200
Z1000j lawson race bike,
Versys 1000gt (2019),
nicomkii
#4 PostAuthor: nicomkii » Sun Mar 01, 2015 3:01 pm
Lay the bike down on a car tire, remove engine mount bolts then lift frame up from the engine. Putting the engine in is revers of the above, easier to manipulate / move frame to avoid scratches than grunting with a bloody motor. ( usually have wheels, forks and swingarm removed too as per full rebuild.
zedward
#5 PostAuthor: zedward » Sun Mar 01, 2015 5:42 pm
Much easier to strip of all your gubbins and lie bike on an old matress or cusions etc on the bikes side. :wink:
Jay1969
#6 PostAuthor: Jay1969 » Sun Mar 01, 2015 8:45 pm
zedward wrote:Much easier to strip of all your gubbins and lie bike on an old matress or cusions etc on the bikes side. :wink:
lol - http://i265.photobucket.com/albums/ii23 ... eeping.jpg
~Jay.
DavidZ1R
#7 PostAuthor: DavidZ1R » Mon Mar 02, 2015 8:53 pm
~Jay.
Made me laugh anyway :lol:
Get the engine out today, with help from two strong men, wernt to bad but your right Jeff, watch those exhaust studs! now to get her cleaned up for the season ahead :D
