Speedo and Rev counter Mounting
walshyco
#1 PostAuthor: walshyco » Fri Mar 13, 2015 4:06 pm
Hi all, can anyone tell me if the Foam/Rubber that the clocks are mounted on is available if not what can I use for this job. I took the rev counter off to change the bulbs and the foam turned to dust, so now they are both a bit loose. Thanks.
Sean. :D
DogsbolloxofZ1B
#2 PostAuthor: DogsbolloxofZ1B » Fri Mar 13, 2015 7:49 pm
Sean,
You occasionally see the die-cut ones for sale on the ebay.com site but to be honest almost all of the ones I have bought are incorrectly cut so you end-up trimming them. I use a 5mm packaging foam fairly 'close' cell that comes with a lot of packaging these days. Does the job just cut to size & stick it down.
Mike
#3 PostAuthor: z1bman » Fri Mar 13, 2015 7:58 pm
walshyco
#4 PostAuthor: walshyco » Sat Mar 14, 2015 2:03 pm
Thanks for that guys, much appreciated, I have ordered some of that and will give it a go. :wink:
