Can somebody please advise the dimensions of the Z900 output shaft O-ring, 92055-035, #31 page 12 of Z Power parts list.
Its the one that sits between the bearing and the sprocket collar.
Output shaft O -ring
- DogsbolloxofZ1B
The one in the gasket kit supplied by Z Power has the correct I/D of 22 mm but it has a thickness of 2.3 mm?
Is that too big or it will compress OK between the inside chamfers of the bearing inner race and the sprocket collar to provide an adequate seal? Or does it need to be replaced for a 1.5 mm one?
- DogsbolloxofZ1B
