A Couple of Questions
wheelysteve
#1 PostAuthor: wheelysteve » Thu Apr 16, 2015 8:56 pm
1. Are the copper washers under the head bolts reusable if annealed or do they need to be renewed each time?
2. What do the 6mm bolts in the cylinder head do ? They look a bit weak to actually do anything!
Steve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
#2 PostAuthor: z1bman » Thu Apr 16, 2015 9:01 pm
yes you can re use the washers. not sure which 6mm bolts you mean ???
wheelysteve
#3 PostAuthor: wheelysteve » Thu Apr 16, 2015 9:04 pm
They are in between the 2 outer head nuts. 6mm X 45mm same as the cam cover bolts.
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
#4 PostAuthor: z1bman » Thu Apr 16, 2015 9:22 pm
they are to apply extra torque to the outside of the head as this is where the oil is supplied
wheelysteve
#5 PostAuthor: wheelysteve » Thu Apr 16, 2015 9:25 pm
cheers Z1bman…..I knew you'd have the answers :D
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Garn 1
#6 PostAuthor: Garn 1 » Sun Apr 19, 2015 12:17 am
Steve, always make sure the surface of the copper washer is smooth and without marks which the oil can track. Beware of outside dia undersize washer often available on ebay (not that you can't use them it's just...!!!). Always anneal to cherry red & quench if re-using.
Note: You only need the copper washers on the four outside, I'm pretty sure early Z1's had copper washers under all 12 head nuts.... Now only 4 required.
#7 PostAuthor: Ginger Bear » Sun Apr 19, 2015 8:18 am
10 washers for £3.00 :shock: 22.3 x 11mm available here;
http://www.ebay.co.uk/itm/Metric-Copper ... 20f9ff6a4f
# 104
Users browsing this forum: No registered users and 90 guests
