I am looking for a key for my z1, number 751, a pattern copy one is fine,
also still looking for a grab rail and headlight brackets (all three bits)
I have seen pattern grab rails and headlight brackets, can anyone recommend a supplier, regards martyn
z1 key
- steve bowdler
Try these guys .
they are very quick and will cut you a key to number.
It will only be a metal top key not a Kawasaki black plastic top key.
The other thing is that the key is cut to original cutting data so will be a better fit than a key copied from a 30 odd year old worn original key as all the wear is transferred to the new key and you will get a replica of your worn out old key.
Just phone them and order by credit/debit card and they will post it to you.
http://www.basildonlocks.co.uk/index.html
