Ive never fitted one, is it easy?, also will the coils need to be changed?
Thanks in anticipation of replies.
Nick
Dyna s
Re: Dyna s
Hasbeen wrote:Ive never fitted one, is it easy?, also will the coils need to be changed?
Nick
Very easy
Standard coils should be ok.
Only 3 wires to connect - I created a small section of 3 wire loom to connect the original wires from under the tank to the Dyna. The Dyna should come with enough wire to join them somewhere safe behind the engine, rather than under it.
Follow the fitting instructions and you shouldn't have any problems.
When life hands you lemons, reach for the vodka.
Z1B (in Z1A colours), Z1000A1, ZRX1100 C4, Suzuki TS125J (being restored), Suzuki T125J (in boxes), Garelli Rekord MKII (awaiting restoration), most of a Garelli Rekord MKI
