Speedo drive width
Coose
Speedo drive width
#1 PostAuthor: Coose » Sat May 30, 2015 3:26 pm
Afternoon all,
Does anyone have a pre-Z1000J speedo drive laying around for a 15mm spindle? If so, could you please measure the width of it for me? I'm in the process of dropping in a Z1300 front wheel and need to space it by 36mm either side. My drive is 39mm, and I will file it down if I need to but if I can source one of the correct width I'd rather do that.
Also, if anyone has a right-hand spacer could you please measure that too as I also need a wider one for that side, though I can get one made if necessary (the stock J spacer is 30mm).
Coose
Users browsing this forum: zapo and 24 guests
