I have the Cams out all the head nuts + the 2 m6 bolts
But it appears to be stuck solid, I don't want to disturb the base gasket
So are there any pry points or has anyone any tips on shifting the head
Cylinder head removal
Z1000 MK2
Z1300 DFI
Z1300 DFI
- ZedHead
Re: Cylinder head removal
Gavin wrote:I have the Cams out all the head nuts + the 2 m6 bolts
Check all the head washers are removed too ...as one or two of these often remain captive & then bind up on the threads of the Head fixing studs & this will rigidly hold your Head in situ...you'll have to prize em out !
Also........ as far as not upsetting your Barrel/Base gasket joint....CAREFULLY locate the ends of a pair of Long tire levers... one on each opposing front & rear side of the Head ...these placed inbetween the & top of Barrel & the underside of the Head, there are Webbing/linking points that are there with good strong structual integrity.....look for them & identify them ..& using these points carefully you won't damage anything! Use the Tire levers in such a way that when you apply an equal downward force on Both of them ...at the same time ! they then in turn will Lift up on the underface of Head & at the same time they are then applying a downward force on the top of the Barrel & this action kill 2 birds with one stone by Lifting the Head & preserving the Base gasket joint. Break the joint one side of the motor a tiny ammount ( say about 15 thou ) .....then do the other side the same ....= Job's a goodun !
I've successfully done this on Zeds many times over the years & on many different motors too, just ensure you act carefully & find the strongest points & the longer the lever the better of course. Hope my explanation make's some sense & helps. Good luck . Johny Brando
