kev edwards wrote:Phil when I had a thou I had years of it faffing around new plugs, condensers, points, coils, dyna system, harness completely stripped and checked, all mechanical timings and clearances done and it still faffed about, I put a two into one back on it similar to originals and bingo no problems ever again.
phil1r wrote:kev edwards wrote:Phil when I had a thou I had years of it faffing around new plugs, condensers, points, coils, dyna system, harness completely stripped and checked, all mechanical timings and clearances done and it still faffed about, I put a two into one back on it similar to originals and bingo no problems ever again.
Kev, I've got a 4 into 1 original Z1R
johny brando wrote:phil1r wrote:kev edwards wrote:Phil when I had a thou I had years of it faffing around new plugs, condensers, points, coils, dyna system, harness completely stripped and checked, all mechanical timings and clearances done and it still faffed about, I put a two into one back on it similar to originals and bingo no problems ever again.
I'm sure the Dyna system is good & I've a CDi MK11 ignition system on my 900 kawa & yeh there both reliable I'm sure......... BUT- hey, with points & condensors you'll always get home if it goe's tits up on you at the side of the road & you can buy alot of points & condensors for 295 sobs. O yeh , I guess your aware that points do normally spark ... but when they really start arcing quite brightly ....yeh there toast & you can test em quickly & easy enough you'll find the simple tests in the manual.
Mmmm, I guess you could always have the best of both world too & carry your spare points plate assy under your seat...just in case ! Cheers Johny Brando.
Users browsing this forum: kev edwards and 49 guests
