Rear wheel offset
GinjaDave
Rear wheel offset
#1 PostAuthor: GinjaDave » Tue Sep 22, 2015 12:20 pm
Does any one know the wheel offset, from hub to rim, on a rear spoke wheel, off of a Z1000 A1? I striped it down to put new spokes in and didn't take the measurement first :oops:
Of all the things I've lost I miss my mind the most
#2 PostAuthor: warren3200gt » Tue Sep 22, 2015 1:22 pm
Not sure it helps but on a 650 its 12mm from hub edge (drum side) to rim edge.
flateddie
wheel offset
#3 PostAuthor: flateddie » Tue Sep 22, 2015 3:31 pm
Got my z1000A1 spokes hanging up in the garage waiting to be overhauled have a measure up on Saturday for you.
THEMACCLADS
#4 PostAuthor: THEMACCLADS » Wed Sep 23, 2015 3:36 pm
Sprocket side 28.2mm
Disc side 28.6mm
Hope this helps. Paul
Beer and Sex and ChipsNGravy - It's all a Macc Lad needs.
flateddie
z1000A1 offset
#5 PostAuthor: flateddie » Fri Sep 25, 2015 8:29 pm
Hi There,
Just measured my A1 spoked wheel with the sprocket carrier out mine is 29.5mm from the hub to rim.
good luck
Eddie
GinjaDave
#6 PostAuthor: GinjaDave » Mon Sep 28, 2015 5:45 pm
Thank you very much gentlemen that's very helpful.
Regards Dave
wayno
#7 PostAuthor: wayno » Tue Sep 29, 2015 6:44 am
Out of curiosity is there an offset on the z900's a4?
