z650 alpha (alfa?) 4 - 1
#16 PostAuthor: warren3200gt » Fri Oct 30, 2015 10:00 pm
Are you worried which side exit?
Gus
#17 PostAuthor: Gus » Sat Oct 31, 2015 3:05 pm
warren3200gt wrote:http://www.ebay.co.uk/itm/Kawasaki-Z-KZ-650-Micron-Exhaust-/281837727221?hash=item419ed66df5:g:q4QAAOSw5VFWK6wF
I've got exactly the same exhaust on my 650 but it doesn't have the badly aligned micron badge bodged on to it.
Gus
"Set the GRINDER on it"
scott reid
#18 PostAuthor: scott reid » Fri Nov 06, 2015 11:33 pm
Hi Warren, no I'm not worried which side it exits, thanks.
Scott
#19 PostAuthor: warren3200gt » Sat Nov 07, 2015 10:08 am
If the weather picks up a bit I'll fit the one I'm building to the bike and post a couple of pics. The only bit still to do is the rear hanging bracket but you'll get the idea.
#20 PostAuthor: warren3200gt » Sun Nov 08, 2015 2:34 pm
Scott
Obviously still got the tail bracket to do but all that's been needed so far is a hacksaw (to cut the tail pipe to the desired length) and spanners. NSR 125 tail pipe hanger bracket is 60mm diameter then just need to hook that up to the rear foot rest mount using existing foot rest retaining bolt. £12.00 from H***A
Baffle ebay £25.00
http://www.ebay.co.uk/itm/371189634663? ... EBIDX%3AIT
Wadding ebay £10.00
http://www.ebay.co.uk/itm/131629550112? ... EBIDX%3AIT
Quick trip down the sports trophy shop for an etched/engraved plate with whatever you like on it £3.00 (if you like silly sh*t like me!)
Tail pipe 60mm stainless tube ebay £13.00
http://www.ebay.co.uk/itm/111428228124? ... EBIDX%3AIT
Tail pipe collector joiner ebay £12.00 Collector box end is 64mm ID and the tail pipe end is 60 ID. This is a stainless Harley bit. The Delkevic collector box is 64mmOD and the tail pipe is 60mm OD.
http://www.ebay.co.uk/itm/281647241208? ... EBIDX%3AIT
Stainless down pipes and collector from Delkevic £170.00
http://www.ebay.co.uk/itm/291396434814? ... EBIDX%3AIT
So complete stainless Piper/Alfa rep for £230.00 new with the added bonus that you have whatever length tail pipe takes your fancy.
Redbeard
#21 PostAuthor: Redbeard » Sun Nov 08, 2015 4:38 pm
Very neat and professional, thanks for the links too :wink:
1979 Z1000ST
PJ
#22 PostAuthor: PJ » Sun Nov 08, 2015 4:43 pm
Now that looks great - well done
#23 PostAuthor: paul doran » Sun Nov 08, 2015 6:32 pm
That seems amazing value
johnfinn
alfa exhaust
#24 PostAuthor: johnfinn » Sun Nov 08, 2015 7:05 pm
i have a piper exhaust totaly solid/ they have thick steel/ yours for 130 quid been hanging up in my garge for years
Thanks,
John
scott reid
#25 PostAuthor: scott reid » Mon Nov 09, 2015 8:56 pm
Thanks John, I have sent you a PM
Warren, thanks for the info and photos, it's food for thought.
Scott
#26 PostAuthor: warren3200gt » Thu Nov 12, 2015 3:18 pm
Finally got 10 mins to fit the tail pipe bracket. Fortunately it fits straight onto the rear footrest pin. No drilling or bending required! clamped in place between the frame and the footrest bracket.
It's stock H**** NSR 125 at 60mm dia
scott reid
#27 PostAuthor: scott reid » Wed Nov 25, 2015 6:07 pm
That looks great Warren!
Thanks for the info and pics.
Scott
