Headlight Bulb
- wheelysteve
Headlight Bulb
What is the best H4 (wattage) headlight bulb to fit on a UK spec Z1B without overloading the 40yr old standard electrics?
Cheers Steve
Cheers Steve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
- wheelysteve
- SVENLEATHER
- mick znone
found this on a quick search, may find a lot more on a longer one
http://z1ownersclub.co.uk/forum/viewtop ... mp+upgrade
Use the original wiring to switch a relay which is fed from a higher rated fuse ,wiring and is capable of handling the extra current,you can then safely fit high output lamps.
Osram 'Night breaker unlimited' are standard fit H4 bulbs - extra output without using more amps.
Halfrauds etc...
As Paul says - the standard 40 year old wiring/switches can be used to operate a relay - micro relays from auto electrical supplies would fit inside the headlamp shell.
http://www.autoelectricsupplies.co.uk/p ... tegory/194
z-fever do a clear 7" headlamp which I am toying with using.
http://www.z-fever.de/ShopNeu/shop/popu ... boscnicsk7
Non original appearance could be a deal breaker!
Halfrauds etc...
- RALPHARAMA
The standard H4 fitment is 55/60watt, which will work fine on your bike providing the wiring's not shagged. If the wiring is knacked then a new loom is not a huge investment from Z Power and they also sell pattern switches. Whilst the switches aren't as good quality as the OEM ones, they are loads better than a shagged out stocker!
I think that the wiring on most Zeds is getting beyond it's sell by date these days and I have rewired dozens of them now. I wouldn't say I can actually do 'em with my eyes shuts, but I'm getting there
Ralph Ferrand
- wheelysteve
