Headlight Bulb
- wheelysteve
- wheelysteve
Got some of these from Eurocarparts. Half price plus extra 10% off so worth a punt. Might go down the relay route to get max benefit.
Anybody know what size fuse/cable is required for the bulb supply if using a relay ??
Cheers, Steve
http://www.eurocarparts.com/ecp/p/car-a ... &0&cc5_847
For 10% off, use code EXTRA10
Cheers, Steve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
- RALPHARAMA
H7's are no use on a Zed. You need H4.
You can use 1mm² for the switch side and 2mm² for the load side.
Ralph Ferrand
- wheelysteve
- wheelysteve
Serps wrote:A 10 amp fuse will do as the bulb will draw 5 amps.
W/V = A 60/12=5
As Ralph says the issue is more with the old Zed wiring looms. The cable thickness's he has suggested are more than adequate also use thin wall.
http://www.vehicle-wiring-products.eu/p ... sq-28-0-30
Users browsing this forum: gpzer and 52 guests
