voltage regulator/rectifier
buzzard
#1 PostAuthor: buzzard » Mon Dec 14, 2015 1:21 pm
Anyone out there got any info on regulator/rectifier all in one units, which ones are anygood? Where to buy one? Thanks Buzzard.
Every man should have a shed (for bikes obviously..)
z2.john
#2 PostAuthor: z2.john » Mon Dec 14, 2015 2:58 pm
jimmock
#3 PostAuthor: jimmock » Mon Dec 14, 2015 4:24 pm
The "combined unit" is the ONLY way to go.
I'm sure a GPZ550 is the SAME???
Jimmock. :wnkr
I hate people I don't like !
jimmock
#4 PostAuthor: jimmock » Mon Dec 14, 2015 4:25 pm
Jimmock. :wnkr
#5 PostAuthor: PAULJAC47 » Mon Dec 14, 2015 4:31 pm
Used all sorts,including cheapo ones of ebay and Hodna wet dream units,as long as 3 phase had no probs...
#6 PostAuthor: chrisu » Mon Dec 14, 2015 5:57 pm
z2.john wrote:https://www.z-power.co.uk/merchantmanager/product_info.php?products_id=41
These work well
Plug and play but quite expensive.
There are plenty of 3 wire ones out there much cheaper of you don't mind a bit of wiring.
Mark Tiller
#7 PostAuthor: Mark Tiller » Mon Dec 14, 2015 7:20 pm
07962421462
ADE
#8 PostAuthor: ADE » Mon Dec 14, 2015 7:41 pm
I have a wassell on mine no problems as yet and easy to wire
Ade
Gavin
#9 PostAuthor: Gavin » Mon Dec 14, 2015 10:06 pm
I have a wassell on my 900 gives a good charge to the battery and has been no problem
Z1000 MK2
Z1300 DFI
buzzard
reg/rect
#10 PostAuthor: buzzard » Wed Dec 16, 2015 11:11 am
Thanks for the info lads. Buzzard.
RALPHARAMA
#11 PostAuthor: RALPHARAMA » Wed Dec 16, 2015 1:47 pm
I always buy from Electrex world. They are made in the UK, not sourced from China and have excellent after sales service!
Ralph Ferrand
johny brando
Re: voltage regulator/rectifier
#12 PostAuthor: johny brando » Sat Dec 26, 2015 4:04 am
buzzard wrote:Anyone out there got any info on regulator/rectifier all in one units, which ones are anygood? Where to buy one? Thanks Buzzard.
Dittto.... PAULJAC47 reply to you below. Auto- Jumble or Breakers there
plentyful , good n cheap. I used one & used my existing Regulator plug & 2 inch wire tails which I then Crimp connected ( but ensure you use a proper/good crimping tool & heat shrink, as solder is too brittle ) to the H**** wire tails & it then just plugs straight back in again to the other existing Regulator plug & Bob's your Dad's brother !.....................O yeh ,unplug & remove existing Rectifier now as it's now redundant.
Search Forum for the wire colour coding that you'll need to follow ...it's easy ....must be, as I did !!!!!! yours, Forest Gump . :D
#13 PostAuthor: ADRIAN H » Tue Dec 29, 2015 8:55 pm
vduk wrote:I always buy from Electrex world. They are made in the UK, not sourced from China and have excellent after sales service!
+1 :D
walshyco
#14 PostAuthor: walshyco » Fri Jan 08, 2016 9:41 pm
Ralph have you fitted a combined reg/rec to an A1.Electrex don't list one as that is not the standard set up. So wich is the best one to use??? Sean.
Bps
#15 PostAuthor: Bps » Fri Jan 08, 2016 10:17 pm
I note that Electrex have taken off the combined regulator/rectifier - not sure why as they had it there for so long
Here is what is fitted to my bike - the RR10 is the combined unit
The charging system consists:
Electrex billet RO99 rotor and G90 stator
Electrex combined RR10 regulator/rectifier
I would call them and ask why the RR10 has been taken off the site
Users browsing this forum: Bing [Bot] and 43 guests
