Carb to much fuel
Carb to much fuel
I was running a Harris with competition baffle .now have a marshal deep tone .bike is not starting well . And a flat spot between 2500 rpm and 3500 rpm .have fitted hotter plugs plugs still very black and droped needle one groove . Think it's time to rejet any body know best size to try. Also has v& h filters Kawasaki z1100r
jez1100r wrote:Droped pilot jet to 35. From 37.5 ,air jets now at 2.25 turns out . Starts better .still have flat spot at 2500 rpm to 3500 rpm .any more surestions
i would jet down on your mains , on my ut i ended up all 4 the same ,no need to have bigger mains on 2-3 ! {i got that info from this site}.
go down one size at a time ,and test / plug chop , mine is on standard settings and 147.5 on all 4 with A.P.E foam air filters and V & H pipe (race baffle)
if i try and quieten the pipe to much it runs shit slow and motor gets hot !!!
do not use cheap air filters !!
Changed main jets today 2 sizes smaller . On reassembly started fine on choke about 2500 rpm left to warm up after 30seconds or so started to rev at 4000 .pused choke in but stayed a 4000 rpm . Checked al throttle connections nothing wrong.turned air jets down but still ran at 4000 rpm .sprayed wd40 round inlet rubbers no change
