Spark Plug Threads !
thezfactor
#1 PostAuthor: thezfactor » Mon Jan 04, 2016 8:15 pm
Has anybody come across this problem before ? All four spark plug threads on my Z900 cylinder head are pretty much shot, no problem I hear you shout. I've got a Helicoil kit to correct the problem. Now here's the rub, it turns out that one of the holes has already got an insert in it ! I've taken the loose insert out, and the insert tap is a very pissy fit (engineering term) in the hole, no metal has been cut but a new insert inserted, and the result is the same "unusable". The Helicoil tap cannot be any bigger as it is just about to touch the valve seats now !
jimmock
#2 PostAuthor: jimmock » Mon Jan 04, 2016 8:48 pm
Sounds like a nightmare.
Jimmock. :wnkr
I hate people I don't like !
#3 PostAuthor: z1bman » Mon Jan 04, 2016 8:49 pm
loctite the helicoil then use a thread chaser to clean the helicoil
http://www.ebay.co.uk/itm/like/19124417 ... ue&ff13=80
1962royp
spark plug threads
#4 PostAuthor: 1962royp » Mon Jan 04, 2016 9:58 pm
I had this with my B2
Take to an engine builders he will put a steel insert in. back to std
GPZ1100 B2 owner
GPz 305 project
99% Gpz1100 unitrac Nearly there runs just needs paint.
1100 Zephyr Project.
1981 KZ1000 LTD
z1000puddin
#5 PostAuthor: z1000puddin » Tue Jan 05, 2016 12:36 am
I had one like this in my A1 Thou head
Big sert is a next stage up time sert
http://www.timesert.com/html/bigsert.html
Zed til Dead
thezfactor
#6 PostAuthor: thezfactor » Tue Feb 09, 2016 12:56 pm
Image[/img][/url]
As you can see here the helicoil insert was touching the valve seats.
So I have decided to tap the hole out 3/8 bspt and make a special plug to fit.
The downside is I will have to do all four cylinders.
And I will fit 10mm spark plugs.
Here is one of the four off plugs that have been made, complete with a hex drive to be inserted into the head.
Plug fitted.
Spot faced off to achieve a flat face.
A bit more dressing off still to be done.
There you go job done x 4.
#7 PostAuthor: PAULJAC47 » Tue Feb 09, 2016 3:31 pm
Nice work John...
#8 PostAuthor: kev edwards » Tue Feb 09, 2016 3:32 pm
A man after my own heart, thinking outside of the box and a bloody good solution to a problem that rears it's head too often, that is much better than sending it to scrap, though some will scoff at it, this sort of thinking saved many £'s on my old thou.
andy c
head
#9 PostAuthor: andy c » Tue Feb 09, 2016 5:30 pm
John,
Nice job, a man after my own heart.
