Zincing carb bits
Zincing carb bits
#1 PostAuthor: PAULJAC47 » Tue Feb 09, 2016 3:30 pm
Just took some bits off a4 carbs for zincing,on Steve Smethhurst site says to avoid zincing choke lifter as is hard chromed and may damage rod,anyone know anything about that?
#2 PostAuthor: z1bman » Tue Feb 09, 2016 5:22 pm
not the choke lever he is talking about arm which lifts the carburettor slide ?
#3 PostAuthor: PAULJAC47 » Tue Feb 09, 2016 6:03 pm
Bit vague,i reckin the choke bar can be zinced?
#4 PostAuthor: z1bman » Tue Feb 09, 2016 6:15 pm
choke bar can be done i have had them done before
#5 PostAuthor: Ginger Bear » Tue Feb 09, 2016 7:32 pm
Smethurst is talking about the little 'dumbbell' that is lifted with the choke bar.
# 104
#6 PostAuthor: z1bman » Tue Feb 09, 2016 8:08 pm
a4 carbs don't have this part smethurst is mentioning it is a different part on the a4 compared to the z1/a/b it is concealed under the carb tops where as on the z1/a/b the lever/ arm is on the outside of the carb
#7 PostAuthor: PAULJAC47 » Tue Feb 09, 2016 9:33 pm
confused now!
#8 PostAuthor: z1bman » Tue Feb 09, 2016 9:46 pm
this is the part smethurst is talking about but it is not fitted to the z900 a4. on the a4 its an aluminium part & you cannot see it from the outside you have to remove the top from the carburettor to see it
this is the part & its only fitted to z1/a/b type carburettors
this is the part that does the same job on a 900a4
http://www.ebay.com/itm/Kawasaki-NOS-NE ... 0994323142
#9 PostAuthor: PAULJAC47 » Tue Feb 09, 2016 9:47 pm
ok thanks!
#10 PostAuthor: Ginger Bear » Wed Feb 10, 2016 6:20 am
Paul's, sorry for any confusion. :??
In my defense it had been a long day and I'd started early on the shandy. :wink:
# 104
#11 PostAuthor: PAULJAC47 » Wed Feb 10, 2016 9:11 am
Ok Guys Thanks for advice!
z2.john
#12 PostAuthor: z2.john » Wed Feb 10, 2016 11:13 am
I believe the part being referred to is 16041-017 as in the link below. Do not zinc this
http://www.ebay.com/itm/Kawasaki-KZ1000 ... 2043142485
