Having just got my Z1B started after about 6 years sitting around and having gien it a bit of a top end overhaul - the clutch doesn't seem to work. The cable is new and the pushrod operates okay but it seems like the clutch is stuck - does anyone have any suggestions as to what the problem might be and how to sort it out.
Thanks.
Clutch Not Working
- london calling
Sounds like the clutch is stuck to me too! As it's been stood for such a long time you would probably be best to take the cover off and take out the plates and wipe some oil over them. Sometimes smacking them into gear doesn't free them up when they have stood for a long time.
Stuck clutch huh
Ok. strip and prize the plates apart,degrease,any rust deposits? OK,sand the muck off with some fine wet/dry on a flat surface, clean,then lubricate with engine oil rebuild,lube othe associated clutch parts,adjust and ride away
My Z1-R clutch was seized,i followed the above process and its still working fine
The new plates are sat in the Achives of the Hangar
Users browsing this forum: Bing [Bot] and 34 guests
