GPZ11 Unitrack problem
#1 PostAuthor: paul doran » Tue Apr 19, 2016 10:21 pm
One of Our lot over here is having a problem with His 1100 Unitrack it still has it injection system fitted when He runs the bike it is showing a fault 1 long flash on the led display followed by 3 short flashes He only has the handbook and its says it's the heat temp sensor any ideas
KWACKERZ1
#2 PostAuthor: KWACKERZ1 » Wed Apr 20, 2016 8:53 am
The unitrac i had used to flash up a fault intermitently if the battery was low.
worth a check.
mike_p
#3 PostAuthor: mike_p » Wed Apr 20, 2016 9:31 am
Yep.....1 long then 3 short is engine temp sensor fault. Might be worth checking the connection to it as it may have just come off
flateddie
#4 PostAuthor: flateddie » Wed Apr 20, 2016 1:15 pm
mine used to go every 9 months they used to be £45 from Kawasaki back in the day
#5 PostAuthor: Ginger Bear » Wed Apr 20, 2016 2:33 pm
The connector to the sensor is prone to corrosion, as is the wire.
Cut the connector off & strip back the wire to expose some nice fresh copper.
Then fit a new connector. :D
From memory, the sensor also fits into a boss, then screwed into the head. It's worth taking it all out & checking both sets of threads for corrosion, as these will effectively increase the resistance of the sensor. :??
# 104
Users browsing this forum: KevH and 63 guests
