Just finishing the rebuild and fitting the loom on z900A4
But having difficulty deciding where to put the 2 earth leads
1 is longer than the other
1 fat end must bolt onto the engine by the kickstart
1 fat end must be a battery negative
1 fat end must bolt onto the frame near the rubber tank strap
But where does the 4th fat end go?
Ive got the 2 thin wire male bullets sussed- 1 is attached to the battery box mounting bolt via a ring connector and 1 goes to the earth lead with a female bullet coming out the loom
My photos taken prior to the strip down don't show it well , and Dave's restoration book isn't clear on it
With thanks
Earth Leads
Earth Leads
gray
