Cam timing
King of Kings
Cam timing
#1 PostAuthor: King of Kings » Sat Jul 02, 2016 3:15 pm
Have just fitted new top camchain idler wheel assembly, come to check cam timing as per manual, and its massively way out! :?? Not just an odd tooth, but nearly half a cam sprocket's worth?? :shock: Ran great beforehand?
#2 PostAuthor: z1bman » Sat Jul 02, 2016 5:43 pm
it should look like this ? look at the cutaways in the end of the camshafts half of the cutaway should be below the cylinder head / cam cover mating surface when it is bang on
RAYZ1
#3 PostAuthor: RAYZ1 » Sun Jul 03, 2016 10:32 pm
how can the tensioner wheel adjust or change the cam timing other than by a very small amount , surely its top dead, fit the cams the right way as per book and count the links after that fit the tensioner :roll:, if its out by a tooth or more then the cams wer set in the wrong position relative to tdc ?
King of Kings
#4 PostAuthor: King of Kings » Mon Jul 04, 2016 12:49 pm
Your correct, all sorted now, thanks! :)
Users browsing this forum: No registered users and 88 guests
