No electric's 1977 Z1000A1
Sam Johnson
#1 PostAuthor: Sam Johnson » Sat Jul 23, 2016 5:30 pm
Just been out on the bike did about 80miles, no issues running great all electric's working. Went to make a right turn at very low speed to call on my elderly mother and the bike stopped DEAD. No ignition lights nothing!
Checked the main fuse, its fine, battery is fully charged. Wiggled all the wires I could see still nothing.
Pushed it up the hill to my mothers and put it in her garage.
Any ideas as to what to look for etc?
Thanks in advance
Sam
#2 PostAuthor: Pigford » Sat Jul 23, 2016 5:55 pm
Either fuse box ceonnections or fuse.... make sure fuse is locating in holder prongs.
Connection to ignition switch dodgy.... block at headstock or in h/lamp?
Farmer
#3 PostAuthor: Farmer » Sat Jul 23, 2016 6:10 pm
Change the fuse, I have had a few (5 so far this year ) main fuses blow right at the end and the fuse still looks ok , I put it down to Chinese made shite. :D
1981 KZ1000 K1 LTD
Chris Riv
Loom broke
#4 PostAuthor: Chris Riv » Sat Jul 23, 2016 8:48 pm
Wiring loom broken where it goes round the headstock?
Tonka
#5 PostAuthor: Tonka » Sat Jul 23, 2016 10:40 pm
Ignition switch or connection.
Inheritance? What inheritance? He spent it all on booze, women and Zed parts!
Kev1R
#6 PostAuthor: Kev1R » Sun Jul 24, 2016 1:00 am
As per Pigford
FUSES --
Sometimes the ends of the fuse vibrate away from the contact cap at the end - so they can apppear at at glance to be ok but actually have vibrated loose.
Well worth double checking
010
#7 PostAuthor: Garry.L » Sun Jul 24, 2016 11:16 am
If it is a fuse then they blow for a reason, so given he was turning the bars when it all went dead I'd be looking at looms around the headstock area.
Sam Johnson
No Electric Power
#8 PostAuthor: Sam Johnson » Sun Jul 24, 2016 11:25 am
Gents,
Thanks for all the advice it was very helpful.
Problem now SORTED, it was the connection block from the ignition switch
to the power supply by the headstock. Will clean the block up when I get time and make sure there is plenty of 'loose' wire around that area.
Thanks again to all
Sam
steve bowdler
#9 PostAuthor: steve bowdler » Sun Jul 24, 2016 1:01 pm
I would still think about changing to blade fuses
