Hi Guy's
I would like to get my crankcases, barrels and cylinder head cleaned and either painted or powder coated.
Can you recommend anyone in Central Scotland or even NW England ?
Thanks in advance
Robert...
Engine cleaning and painting/powdercoating
Rust Never Sleeps !!!
Thanks 000zeds
I don't think he offers a painting or powder coating service.
Might have a word with him regarding the cleaning, it's £280 for a ceramic clean which although would be top notch, it could be a bit OTT for something
that is going to get painted or powder coated.
it would be criminal to paint the engine after you have had it ceramic cleaned by smethurst. vapor blasting is a much cheaper process if you are going to paint it. powder coating retains heat so could cause problems if its a tuned motor i would do the painting yourself & use wurth high temperature Matt black which dries to a satin Finnish & is the only paint i ever use on air cooled engines
Paint on ceramic clean
Deffo don't put paint on a ceramic clean. There is nothing for the paint to hold onto, it will fall off in no time. I know, I have been there......
Hi All,
Thanks for the advice and tips, have contacted Steve Smethurst and will be taking the parts to him on my next visit down South.
There is a possible fly in the ointment in that it had been previously blasted and powder coated, I have had the powder coat chemically stripped, which has revealed that the alloy surface may be too rough/imperfect to get the best results from vapour blasting, which is why I was considering a paint finish !
Talking about paint finishes, Camcoat in Warrington came highly recommended by Steve Smethurst. Anyone on here have any experience good or bad with their work ?
Users browsing this forum: zapo and 54 guests
