Revs won't die down.
Z1b , carbs cleaned, new jets etc, set on bench then checked with vacuum gauge's.
New inlet rubbers, (sprayed with wd40 when running and no change in revs),
ign timing ok (dyna s),
valve clearances ok apart from number 1 inlet very slightly tight, number 2 inlet very slightly slack.
Tickover is lovely and smooth/quiet,
When cold seems almost ok but when riding or when it's warmed up the revs take a while to die down. Pulls ok when ridden, over say 3,000 rpm all feels ok.
If I turn the tickover down it stalls at junction's etc but still doesn't die down even when riding and pulling clutch in it still holds onto its revs.
Airscrews set at 1 1/2 . I've tried different positions for the airscrews, ie turning out till revs rise then reset the tickover screw etc.
Cable free play set ok.
Beginning to run out of ideas.
Anyone suggest anything please guys.
Z1b,
zxr750 m2,
zrx1200
Z1000j lawson race bike,
Versys 1000gt (2019),
zxr750 m2,
zrx1200
Ok, I think I've got that.
That will be 10mm gap underside of throttle stop or idle screw to bracket.
Then adjust the eccentric bolt/screw that's stops the pulley that the closing cable fits into.
Z1b,
zxr750 m2,
zrx1200
zxr750 m2,
zrx1200
Z1parR wrote:Bike is over 40 years old Pete and you're over 50 years old ,
I can see a problem here already
And just what do you mean 🤔
I'm hoping to get it sorted so I can go to jester's rally on it in a couple of weeks.
Z1b,
zxr750 m2,
zrx1200
zxr750 m2,
zrx1200
Wasn't me that actually did them. It was someone on here and what a good job he's done. I've no cause to think he did anything wrong because it was doing it before he cleaned them. It's done it since I bought it a few years ago but it's not been used till I rebuilt it.
Z1b,
zxr750 m2,
zrx1200
zxr750 m2,
zrx1200
Sounds like its running lean,are you sure no air getting into head rubbers,standard air filter? all jets standard for bike and clip on middle on needle?
floats height set ok?early carbs are a bit of a faff if they the separate ouside adjusters for balance,might be worth re checking,ihave you tried a colurtune?
Would defo try a colourtune first,trouble is with swapping carbs is if the head rubbers are a bit old you never seems to be able to get em to seal properly again,sorted out loads of probs with the colourtune,just a thought you say you have dyna s ,it is advancing all the way to the full advance mark past the bob weights and retuning? and has the correct rotor ? not being the early z one?..Paul J
Carb rubbers are new. I didn't use any instant gasket but I've sprayed them with wd40 and no change in revs.
I'll try a smear of instant gasket but it did it with the old rubbers.
I'll recheck the ignition but I'm 99.9 % sure it's correct.
Next I'll give the colourtune a go if I can find one round here.
It seems ok when I first start it but as it warms up it then starts acting up.
Z1b,
zxr750 m2,
zrx1200
zxr750 m2,
zrx1200
If it gets worse when it is hotter....it is too rich, drop your mains and/or needle. If it gets better when it gets hot, it is too lean, do the opposite.try taping up air intake on airbox and see what diff that makes..Good luck Paul J
Ok Paul I'll try that. I've a new air cleaner fitted. Did have a k&n but I've put a standard one in and it's the same. I would think the k&n would flow more air compared to the standard one.
Thanks for your help guys, busy day tomorrow by the sounds of it.
Z1b,
zxr750 m2,
zrx1200
zxr750 m2,
zrx1200
