Front disc tab washers
				steve big zed
 - Regular Poster
Hi all, I have new tab washers for the disc bolts but when I torque up the bolts they twist the tab washers any one have any answers thanks steve
						- wheelysteve
Did you have any luck getting round this Steve?
I've got the same issue but haven't figured a way of not twisting the lock washers. They are the same thickness as the ones I removed ( but are not Kawasaki items).
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
						1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
				needaz1100r
 - ZedHead
wheelysteve wrote:Did you have any luck getting round this Steve?
Have you tried with an air impact wrench? The short sharp shocks may 'knock' the bolt round before the tab washer has chance to snag and be drawn round with it, especially wit a drop of synthetic oil under the head. the actual torque, beyond being tight, isn't too critical.
If you wanted to run the wheel round to Woodley I'd have a go with you if you don't have an impact wrench and compressor.
Mark.
						Mark.
- wheelysteve
				needaz1100r
 - ZedHead
- wheelysteve
I seem to have minimised the distortion by taking all the sharp edges from the underside of the bolt heads (new bolts used), and polishing them on my buffing wheel. A bit of oil and gradual tightening and they are tight.
In the Clymer book it states the the torque setting for the disc bolts at 30 foot-pounds which seams high ?
The original Z1 service manual states 140-190 in pounds ( 12 - 16 ft lb ).
Bit of a difference . What's the right figure ?
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
						1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
- wheelysteve
