Mirrors
tlc wrote:Pattern mirrors blur after 30mph.
Genuine ones do it after 60.
Chrisu bought some pattern ones and put in some anti vibration material which improved them considerably.
Not quitecorrect chris. I bought a set of short stem mirrors off ebay from a company called yuniparts. These had metal/rubber mountings which damped vibration. I just swapped the stems for std Z length ones.
Sadly looks like they don't do them any more. I guess you could contact them to see if they do have any.
If you look on ebay find some pattern type mirrors but ensure the stem goes into a threaded portion on the mirror not into a brass bush which is pressed into the cheap repro ones ,then just swap the complter mirror inserts,need a bit of fiddling but i have done this with some success and no vibes!
From a previous thread I believe KeithZ1r recommends these which are similar to originals and come in long stem or shorter stem (for Z1R) and apparently do not vibrate.
http://www.ebay.co.uk/itm/221245531641? ... EBIDX%3AIT
From experience I would avoid the 'Emgo' make of mirrors as they simply do not work.
Kevin
Kevin
010
- wheelysteve
I've got those on long stems also. They are virtually identical to the original Kawasaki items, only difference is a slightly rougher finish on the back.
I put foam in the back of mine just to make sure and they are rock steady at any legal speed Wink
I think the right hand mirror is a new genuine Kawasaki item, the other is the Yuniworld job
_________________
_________________
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Kev1R wrote:From a previous thread I believe KeithZ1r recommends these which are similar to originals and come in long stem or shorter stem (for Z1R) and apparently do not vibrate.
Kevin
That's them. Same company
