Dymag sprocket spacer/cush drive
Coose
#1 PostAuthor: Coose » Sun Oct 23, 2016 7:17 am
Morning all,
This is a bit of a long shot, but would anyone happen to have either the spacer or a cush drive that fits between an old Dymag rear wheel and sprocket? It had 5no. 10mm holes on a 90mm pcd, a 75mm bore and is 15mm wide.
Coose :)
martinz1000r
#2 PostAuthor: martinz1000r » Sun Oct 23, 2016 9:44 am
Try TPCS. Steve may have spares.
http://tpcs-magnesium-refurbs.co.uk/
Coose
#3 PostAuthor: Coose » Tue Oct 25, 2016 2:46 pm
Cheers. I tried Steve and he was extremely helpful in advising that the wheel is from a TZ500 and thus never had a cush drive as the TZ has one in the clutch. It looks like I'll have to get one made as mine is a 5-bolt fixing and a Dymag one (if you can find one) is 6-bolt on a PCD of 100mm...
