I'm in the process of getting this kz up and running after a long layup, around 15 years it looks like by the dates on the tyres.
After a bit of basic recomisioning I've had it fired up and running...but not very well as it wouldn't tick over and the revs kept climbing as the bike warmed up....after a bit of scratching about it appears two of the carb slides have somehow been butchered by the dpo and have very limited movement in their bores causing the slides to lock up and not drop causing the racing tick over.
So reason for this post is I need a pair of slides to get me on the road, I'm assuming the carbs are standard, they look like every other a1 I've seen with the mixture screw underneath. I've looked at Z power but they don't list carb slides, I was wondering where else do people get carb spares for there kz's or if anyone has a couple going spare.
Rob.
KZ1000a1 Carb slides needed
- 8 Valve Mark
slides
try nrp in Manchester.they do all sorts of carb spares.good luck
